Zum Hauptinhalt wechseln
Samsung Galaxy S21 FE (Fan Edition) ist eine Variante des S21 Models, das am 11. Januar 2022 veröffentlicht wurde. Das Gerät hat kleine Veränderungen im Vergleich zum regulären S21, was das Gerät etwas günstiger macht.
Wi-Fi/Hotspot antenna not working at all
I have dropped my phone a few times no significant damage done to the phone until about 3 days later I noticed the adhesive that holds the back of the phone on was separating on both sides and noticed that my phone won't connect to home/public Wi-Fi or let me use my hotspot. I search for network but absolutely NO networks can be found at all. I still have 5g phone service and my Bluetooth is 100% functioning properly. I believe the Wi-Fi antenna has shifted from the falls or possibly dirt could've gotten into the gap where the adhesive has separated or could very well be damaged completely. I took my phone into a fix it place and they told me that I would have to replace the motherboard and it's impossible to repair just the Wi-Fi antenna only costing me $797! They never actually inspected my phone to begin with to confirm if infact it was my Wi-Fi antenna or something else. I believe it can be fixed and I shouldn't have to spend so much money and replace the motherboard for that 1 thing. I'm confident I can do the repairing myself if I knew the proper steps and diagram of the procedure and have the proper tools that's needed of course. Hopefully this can be done with least amount of money spent. Could someone please help me figure this out please?
Thank you in advance, very much appreciated!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @bluue722
The WiFi antennas are located in the back cover.
Given that you said the cover is separating from the frame, most likely the antennas have lost their connection with the systemboard.
Try holding the back cover firmly onto the frame, both at the top and the bottom of the phone, without putting too much pressure onto the screen and check if the phone now detects WiFi networks.
Maybe best done as close as possible to a WiFi router (<20cm) so as to maximize the signal reception.
If it is the loose cover that is the problem, here's a video that may help to fix it. It shows how to replace the battery but to do this it shows how to remove the back cover (view from 1:27 minutes into the video) and also how to replace it (view from 7:10 minutes into the video)
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Bluue722 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 9
Letzte 30 Tage: 45
Insgesamt: 132
