Zum Hauptinhalt wechseln
Die erste große Überarbeitung des 3DS durch Nintendo wurde im Oktober 2014 in Japan und im September 2015 in Nordamerika veröffentlicht. Der 3DS 2015 bietet verbesserte 3D-Funktionen, einen C-Stick, neue interne amiibo-Unterstützung und ein neues Set an Schultertasten.
New Nintendo 3DS xl Y button not working tried the usual whats next
So I have tried cleaning the board contacts, changing the dome sticker. making sure the ribbon/flex cable is on correctly, I ordered a new board same issue. Im currently waiting on a new flex/ribbon cable. but the one I have im not sure shows signs of issues. is there any next steps to try or trouble shoot before I have to just get a new main board?
all the other buttons and functions from that board are 100% fine is really just the y button.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
@infopnxworld let's see what our game console Guru koppie007 has to say.
@dan0 what do you make out of this? Any chance for a solution with this?
von
Hi friend! Sorry for the late response!
von
Einen Kommentar hinzufügen
1 Antwort
Oh shoot I forgot to reply here if anyone faces a similar issue. Then try either changing the main board ribbon cable port/connector. As a temp fix you could also just add something in to apply more pressure to make sure the connector is making contact. I had a friend do the temp fix and it worked like a charm manage to revive a lunala solgaleo new 3ds xl.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Hi!
Did you managed to fix your New 3DS now? It could be related to the cables yes, which is most likely the issue here.
Thanks!
von
I did yes. had to make sure the ribbon cable was making proper contact on the main board end. had to add some paper in between the cable and connector to make sure there was enough pressure and the ribbon cable making enough contact. until I can find someone to fully replace the connector on the main board.
von
Alright, clear! Then it is the connector. Glad that you were able to fix it with a temporary fix :)! Please let us know if you found someone who is able to fix the connector! For this, micro-soldering is required.
von
Antwort hinzufügen
Info PnXWorld wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 107
