Zum Hauptinhalt wechseln
Anleitungen zur Reparatur und Fehlersuche bei der FixHub Power Series | Tragbaren Lötstation, bestehend aus Multifunktionaler Powerstation und Intelligentem Lötkolben. Erhältlich seit Mitte Oktober 2024.
Touch-Safe indicator blinking blue.
My screen on my power station is not functioning, and I was able to still use my soldering iron using the touch-safe indicator for power on and heat up indication. During a recent job my soldering iron stopped heating up and started steady blinking blue.
Before the heat up blink was more of a slow pulse as it started turning orange. My firmware on both the power station and soldering iron is up to date and matching.
I could not find what the steady blue blink represents in any of the documentation. I'm still waiting for parts to become available to replace the screen.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi, @ofglamis I gotchu.
Good news! I think I know the cause to these problems.
The power bank needs a replacement screen, and iFixit sells a replacement display. The iron itself needs a new main board. I have the part links here and here, if you need a shortcut.
While wating for the new screen, you can use the web console. The guide included in the link will teach you how to do so.
Replace a damaged or malfunctioning display for your FixHub Power Station. Bild
Produkt
FixHub Power Station Replacement Display
$19.95
Replace a corroded or malfunctioning main board for your FixHub Soldering Iron. Bild
Produkt
FixHub Soldering Iron Replacement Main Board
$34.95
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thanks for the input, I've been waiting for the screen to comeback into stock for the last few months. It looks like main board for the soldering iron is in the same boat. I guess I'll need to get a new travel soldering station until parts return to stock.
von
Antwort hinzufügen
ofGlamis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 15
Insgesamt: 84
