Zum Hauptinhalt wechseln
Ein Desktop-PC, der aus im Handel erhältlichen Do-It-Yourself-Teilen zusammengestellt wurde, anstatt ein vorgefertigtes System eines großen Herstellers zu sein. Diese können auch von einem Systemintegrator unter Verwendung von Standardkomponenten gebaut werden.
MSI B450 Tomahawk motherboard having POST issues
Hey all,
I just bought an MSI B450 Tomahawk motherboard and Ryzen 7 2700 combo.
For some reason the EZ debug lights are showing an issue to me.
The CPU light turns on, then turns off about 2 seconds later. The DRAM light does not turn on at all. Then a second later, the VGA and BOOT lights light up very briefly then turns off. (See video for a visual) No SSD or GPU is installed. I’ve tried CMOS reset multiple times, ran it without the battery etc. it was having the same issue when a GPU and SSD was present, but the issue was more that I was not getting any picture out of my GPU. But the GPU and SSD do work.
I suspect a BIOS corruption, so I’m planning on reflashing the BIOS and see if that will fix it, but I still wanted to see if there was any other ideas for fixing.
Thanks!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Unfortunately I was unable to get it working via BIOS reflash, so I’m returning it.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
S.I. Dalton wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 148
