Zum Hauptinhalt wechseln
Das Spitzen-Smartphone von Apple für das Jahr 2021. Das am 24. September erschienene iPhone 13 Pro Max besitzt ein 6,7" ProMotion OLED-Display, ein neues Dreifach-Kamerasystem auf der Rückseite und 5G-Konnektivität. Der Nachfolger des iPhone 12 Pro Max.
Old screen( no grounding clips/tabs) doesn't match replacement screen
Replacing screen on iphone 13 pro max. The old screen did not have grounding alignment tabs but the new replacement screen does. Anyone run into this ?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
We've been seeing this a lot on the newer model iPhones like yours. What's happened is that when removing the screen you've managed to separate the screen's mounting frame from the screen itself rather than from the phone frame like it's supposed to. My personal suspicion is that Apple has changed the kind of adhesive used to mount the screen frame to the display assembly, and the new stuff just doesn't hold as well as the older glue did.
Anyway, compare your phone to this picture of what it should look like with the screen removed.
I'm betting you'll see the screen frame still on the phone rather than stuck to the screen like it should be. This picture of the screen is what it should look like; I'm betting yours is missing the black and silver mounting bezel; that's the part that's still stuck to the phone.
The fix here is fairly straight-forward; you just have to go around the edge of the bezel and separate it from the phone. Once it's off you can transfer the front sensor parts to the new display and continue on with the repair.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Yeah I got it figured out after overlooking it some more . Didn’t want to budge at first. Managed to get it ripped out without damaging anything and get the new screen on . No problems so far . Feel like they should put that in the guides that there is a possibility of separating. Thanks for answering . Appreciate it
von
Antwort hinzufügen
Evan H wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 45
Insgesamt: 199
