Zum Hauptinhalt wechseln
The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
I don't know what this problem is, any hints?
So I got a PlayStation3 Slim model CECH-2004A, PAL 120, I guess; and when I press the power button, green light, it beeps three times and then red blinking light. Is it the famous Yellow Light Of Death? What can I do? (weird fact: i checked the HDD and it said it was 40GB, is it possible?)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi!
Yep, sound like YLOD…
First you need to take the motherboard out and remove the thermal paste.
Guide: PlayStation 3 Slim Wärmeleitpaste ersetzen
Pleaee try a reflow first. Guide:Yellow Light of Death Reparatur mit YLOD-Kit (I know that this is regarding the PS3 Phat, but just to give you the idea).
Does that work? Then the solder is broken under the CPU/GPU. Most of the time, this fix is temporary. A reballing will fix it, but is very difficult…
Would try the reflow first!
Please let us know how that goes!
PlayStation 3 Yellow Light of Death (YLOD) Reparatur Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
PlayStation 3 Slim Wärmeleitpaste Bild
Anleitung
Schwierigkeitsgrad:
Mittel
1 - 2 hours
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Hey, could i try using thermal pads instead od thermal paste? I know this will be a tough repair, but I'd like to know if the pads would be more durable. Also, if I repair it and hack it, what temp should I use to try not having this problem again?
von
Hi!
No, you really need to use some new thermal paste. Thermal pads is insufficient and will cause the PS3 to overheat.
For the reflow? I always do it at 430 celcius degrees. Works fine for me. Be carefull for the other components…
von
Antwort hinzufügen
Invisible_guy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 75
