Zum Hauptinhalt wechseln
The HP Pavilion G6-2249wm is a 15.6-inch laptop in the G6 series.
Laptop not turning on, when I plug the charger, the power light blinks
When I plug the charger, the power light keeps blinking and it's white.. even when I try to press the power button.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Google this hp pavilion g6-2249wm blinking for a numbet of ideas.
War diese Antwort hilfreich?
Bewertung 0
@alexiskalenga a flashing white light on an HP laptop usually indicates a power issue, or a problem with the charging system. Let's see if we can narrow it down. start off with the common initial steps.
Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Disconnect the battery Now, hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Bilder zu einer vorhandenen Frage hinzufügen
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
Now, it is also possible that this is a bad RAM module. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove all but one and give it a try.
Use the HP Pavilion G6 Notebook PC Maintenance And Service Guide to work on your computer. Let us know what you find out.
Bewertung 0
Antwort hinzufügen
Alexis Kalenga wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 62
