cata mengatasai laptop yang batrei tidak bisa mengisi
batrei laptop tidak mengisi dengan baik
Translation Indonesian - English
how to deal with a laptop whose battery won't charge, the laptop battery won't charge properly
Ist dies eine gute Frage?
@alimintarwa Start off with common steps necessary to determine what is not working. If your laptop works but just doesn't charge the battery, try this.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Bilder zu einer vorhandenen Frage hinzufügen Let us know what you find out.
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged.
Since iFixit does not yet have any specific guides for this, use something like this video to work on your computer
Translation
@alimintarwa Mulailah dengan langkah-langkah umum yang diperlukan untuk mengetahui apa yang tidak berfungsi. Jika laptop Anda menyala tetapi baterainya tidak terisi, coba cara ini.
Pertama-tama, periksa adaptor daya Anda. Pastikan tegangannya sesuai. Periksa apakah konektornya tidak bengkok, dll. Periksa jack DC-in laptop Anda. Pastikan tidak ada korosi, kotoran, dll. yang menghalangi fungsinya. Bersihkan dari kotoran, dll., gunakan beberapa hembusan udara untuk membersihkannya. Jika semua ini tidak berhasil, gunakan amperemeter dan lihat apakah laptop Anda menarik arus dari charger. Setelah itu, Anda perlu memeriksa apakah motherboard Anda mendapatkan daya. Untuk itu, tentu saja, Anda perlu membukanya. Unggah beberapa foto yang jelas tentang apa yang Anda lihat. Dengan begitu, kami bisa melihat apa yang Anda lihat. Bilder zu einer vorhandenen Frage hinzufügen Beritahu kami apa yang Anda temukan.
Tentu saja, Anda mungkin juga perlu mempertimbangkan untuk mengganti baterai. Baterai yang sudah habis tidak dapat diisi ulang lagi.
Karena iFixit belum memiliki panduan khusus untuk ini, gunakan sesuatu seperti video ini untuk memperbaiki komputer Anda
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 55
