Zum Hauptinhalt wechseln
Apples neues Format der 14er Reihe verfügt über ein 6,7" OLED-Display - wie das Pro Max - ansonsten aber über die gleichen Funktionen wie das iPhone 14 mit einem Zwei‑Kamera-System und dem Bionic A15 Chip mit einer 5-Kern-GPU.
Can anyone tell me what the issue can be, any guess
I have an iPhone 14 Plus that was water damaged. I cleaned the motherboard properly using isopropyl alcohol and then lightly dried it with a heat gun just enough to evaporate the alcohol. After that, I reassembled the phone. I cleaned all components the same way except for the charging port assembly. I only cleaned the charging port from the outside and did not remove or clean the flex cable.
I also replaced the battery with another one to rule out any battery-related issue.
After putting everything back together, the issue still persists. When the phone is unplugged and I try to turn it on, it makes a small “cling” sound and then goes directly into DFU mode. It keeps repeating this behavior every time I try to power it on.
When I connect the phone to a laptop while it’s in DFU mode and attempt to restore it using iTunes, the restore process starts but freezes halfway through. The screen stays stuck for a long time and does not complete. I repeated the process multiple times with the same result. I also tried restoring using 3uTools, but it behaves the same way, the restore begins and then gets stuck halfway.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hello Umer
Well we’ll need more info there regarding the % where it stops on 3utools and a picture of the 3utools restore log would be great as well
I’d assume its a board issue 80% some line is shorted/partially shorted somewhere
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Umer Abubakar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 23
Insgesamt: 58
