Zum Hauptinhalt wechseln
Modell A2159, EMC 3301. Eine Neuauflage des Einstiegsmodells des MacBook Pro. Erhältlich in Silver und Space Gray. Erschienen im Juli 2019.
MacBook Pro A2159 new battery not working but old battery does
I recently replaced the battery in my MacBook Pro A2159. The new battery is not working (the laptop won't turn on), but when I reinstall the old battery, the laptop works perfectly fine.
I have already:
1. Transferred the battery board data cable and ensured it is seated correctly in the ZIF connectors.
2. Verified that the T5 power connector pancake screw is snug and making a good connection.
3. Performed an SMC reset.
4. Tried leaving it on the charger to wake it from a potential deep sleep state.
Everything is snug and tight, but the new battery still shows no signs of life. Is there anything else I should check, or is it likely a defective part?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
From the sounds of what you described the battery was likely bad. Have you reached out to the seller to get an exchange or get your funds returned if you want to try a different supplier.
War diese Antwort hilfreich?
Bewertung 0
Well I think you new battery is fault so I will suggest you to exchange the battery.
Bewertung 0
The new battery is likely faulty or incompatible. If the old one works fine, your MacBook hardware is OK
Bewertung 0
Antwort hinzufügen
France N wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 52
