Zum Hauptinhalt wechseln
Repair guides, disassembly, and troubleshooting information for the fourth generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-040.
What the problem with my x button
So the problem is that I was given a PS5 controller, but when I turned it on, the X button didn’t work, so I couldn’t log into any account. I opened the controller and did some cleaning I found online, but even after that it still didn’t work. I even removed the rubber piece from the PS button and tried to make contact with the X button membrane, but it still didn’t work.
I know it’s not a problem with the rubber because I used the same PS button rubber and touched the circle button membrane, and on the PS5 the controller registered a back action. That’s why I’m asking, because I don’t know if it’s a circuit issue or something with the pins, and I also don’t know how to fix it. I imagine it would require soldering, and I’m not very good at that and don’t have the right tools.
Whoever can help me, I would really appreciate it.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi!
In this case, I would replace the button circuit membrane.
You don’t need to solder for this.
Before you replace it, make sure you got the exact same model as the one that came out.
If you need guides, please let me know!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Jahdread Manso wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 52
Insgesamt: 91
