Why is my engine cranking but not starting, after engine overhaul?
Why is my 2001 RAV4 1AZ Engine cranking but not starting, after engine overhaul?
- The timing is ok
- Have sparks & fuel flowing
- Engine compression tested & ok
Ist dies eine gute Frage?
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 144
Have you tried it with the air filter disconnected? You mentioned everything apart from airflow. If that doesn’t work I’d look at the timing again. Good luck.
von Ted
@ted53890 Hi Ted. Yes, I tried starting the engine with the air filter disconnected but still the same, not starting.
The engine timing was double checked & the timing is ok.
The engine starts, when aero start is sprayed but will cut off after a few seconds.
Did engine compression test as well & the engine compression is good.
Used an OBD2 Scanner as well but, didn't detect any error codes.. Ta
von charles lawson komboi
Sounds like a gasket then. Head gasket, air intake gasket etc. sounds like it’s either sucking in or blowing out too much. Have you tested the compression?
von Ted
@charleslaw16336 "The engine starts, when aero start is sprayed" you got a fuel issue or a timing issue (less likely) most likely is the fuel issue. You have checked your fuel pressures etc?
von oldturkey03
@ted53890 Yes, I did a compression test on all cylinders reading 160 psi.
4 weitere Kommentare anzeigen
