Zum Hauptinhalt wechseln
Asus E410MA-EK945TS 14 inch laptop for everyday use, introduced May 14, 2020. CPU: Intel(R) Celeron(R) N4020 1.10GHz | Maximum: 2.8GHz GPU: Intel UHD Graphics 600 RAM: 4GB Storage: 64GB SSD
Why my power adaptor light off when connecting
My laptop has power problem when I connect power adaptor the light of adaptor turn off
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
@malikkhalil could be a bad charging port or a short circuit etc. start off with some basic testing.
Start with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30 sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out.
If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertung 0
When a laptop charger light turns off upon connection, it indicates a short circuit on the motherboard (often a faulty capacitor or MOSFET) causing the charger to enter protection mode. The issue is rarely just the charger. Immediately stop using the charger to prevent damage and consider professional repair to locate and replace shorted components.
Bewertung 0
Antwort hinzufügen
Malik Khalil wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 47
