3DS doesn't charge or work unplugged, but sees the battery fine
[It's USB-C modded, fiy]
Recently, I've decided to pick up my New 3DS to play some Picross, and noticed that it wouldn't power on. I tried charging it over night, but it still wouldn't work, I assume it never charged despite turning on the charge light.
I checked with a multimeter and the battery only showed 1.2v, so I'll assume it's dead dead.
As I've been waiting for a new battery to arrive, I've been playing it with a power bank attached.
Today, it arrived, and the 3DS doesn't turn on with it. It sees the battery, it shows it's fully charged, but when I unplug the power bank, it immediately shuts off.
I don't want to assume I have a new dead battery just yet, but I haven't opened it just yet.
Pertaining to the USB-C mod, it's only become an issue now, despite around a year of using it, it charged the battery just fine.
Edit: Here is a picture of my board and mod. It's not the best, but I'll get a better one when I can
Edit 2: I think I have found the issue... Those cables aren't meant to be crimped, are they?...
Edit 3: I have tested what I presume to be both F1 and F2 fuses (it's the ones surrounded) and they appear, at first glance, to be nominal. There's a slight voltage drop in the F2 fuse (from 4.3 to 3.7 volts), but not being sure about nominal voltages, I'm assuming they're fine.
Ist dies eine gute Frage?
5 Kommentare
@deathpants time to open it up and to check the circuitry. Could Be that some solder connection on your USB-C mod failed or it could also be that you have a blown component on the board. Since it works with an external power supply but not the battery, I would definitely check the battery connector as well. Again, time to open it up. Once you have it open, take some well focused pictures of your circuit board. Post those with our question. That way we can see what you see and hopefully we can get this fixed Bilder zu einer vorhandenen Frage hinzufügen
von oldturkey03
@oldturkey03 If the USB-C connector failed, would it even work with an external power supply? I guess it could have caused something else to fail, but @deathpants says they've been using it for awhile without issues, so I find it unlikely that the mod would cause something to fail this long after it was made.
von Fixer of Stuff
I'll try and get some good pictures either way, to try and help the brainstorming. Thanks for the help so far
von DeathPants
@fixerofstuff lt depends on the wiring of the mod. Most likely its just a USB-C port connected to the USB circuitry of the 3DS but there maybe a separate battery power connection coming of it. That is why we need to see what is going on. Easy enough without the mod. There are a few inductors and diodes that like to fail.
von oldturkey03
I have now added a picture, as per the request. It's not the best, but I'll add a better one as soon as I have the means
von DeathPants
