Zum Hauptinhalt wechseln
Repair information for the Asus TUF Gaming laptop series.
Why is my laptop overheating and battery discharging!
Laptop is almost exclusively used plugged in with the battery only charging to 60% through the battery saver settings. I used to use it all the time to play intense games like Call of Duty, but it started having issues a couple years into it's lifecycle. I have not been able to use it much since. During gaming the computer appears to overheat and shut off. But when I go to turn it back on it says the battery is on 0%. I'm not a computer saavy person, but my first thing was to open it up and clean out the fan (which wasn't that dusty either). My next option would be to replace the battery since it appears to be a cheap fix (under $50). Any other ideas? Thanks ahead of time.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
@albo52005 let u know what the exact model for your computer is. Besides replacing the battery, this "computer appears to overheat and shut off" would lead me to replace the thermal paste :-)
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I'd say you're on the right track with replacing the battery as the first step; definitely sounds like it's time for a new one, and the symptoms can easily be caused by a dying battery.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
don’t forget to replace the thermal paste/ thermal pads/ Liquid Metal just in case they’re dry or displaced
von
I finally got around to swapping the battery out. So far it seems to have solved the problem! Thanks again everyone.
Bewertung 0
1 Kommentar:
@albo52005, appreciate you coming back and letting us know. This way anyone who comes along with the same problem can be confident that a new battery is likely to fix the issue.
von
Antwort hinzufügen
Albo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 98
