Zum Hauptinhalt wechseln
Repair, disassembly, and troubleshooting information for the Epson Perfection V700 scanner, released in 2006 by Epson. The Epson Perfection V700 is a professional flatbed scanner, and uses a dual lens system for 6400 dpi scans.
changing the bulbs of an Epson V700
My scanner V700 fell down and the light source (bulbs/strips) are now broken. I would like to try to fix it myself but would like to get some advice. Is it easy to find those parts and replace them ? thank you
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Hello,
Thank you for your response !
von
@agatweiss Just happy to be of help :)
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi!
You can use the service manual to find instructions on how to replace the lamp. See page 59 (section 4.2.13) in the service manual, the lamp replacement section begins by mentioning earlier steps needed for lamp removal.
I however cannot help you source a lamp, so I'd say google is your best friend, then you'll find a localized result suitable for your location. If you were to follow the guide and take out the lamp, you may find some part number on the lamp that could help you search for it, although that is not a guarantee.
Good luck,
Cheers
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
agat weiss wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 52
Insgesamt: 54
