How I can replace transmission oil
How I can check transmission oil level
Ist dies eine gute Frage?
@mandeepmaan here are the Atfinstructions for the Ford PowerShift DPS6/6DCT250 which is one of the transmissions used in your Fiesta. Essentially, you open the drain plug to drain the ATF (on a warm transmission only) and use the filler plug to add ATF. You will need to fill until it starts to leak back out of the filler plug.
War diese Antwort hilfreich?
Letzte 24 Stunden: 3
Letzte 7 Tage: 42
Letzte 30 Tage: 169
Insgesamt: 501
@mandeepmaan what exact year and model is your Fiesta and I assume you are referring to an Automatic Transmission?
von oldturkey03
