Zum Hauptinhalt wechseln
Der 2015er Tahoe wurde später zum meistverkauften Fahrzeug im Februar 2014 ernannt und lag bei seiner Veröffentlichung bei einer durchschnittlichen Verkaufsdauer von sieben Tagen.
My A/C is going from hot to cold and back A/C no longer blows
I drive a 2015 Yukon SLT
So I just started having an issue or my AC is blowing cold, but then starts to blow warm, but then starts to blow cold again. I noticed my cooling fans only work when my AC is on, but never engages to the high speed. It should after reaching a certain temperature. I had someone use a scanner to automatically turn on the fans to high and they do work but at the same time this happens my back, A/C doesn’t blow at all no air comes out. I change the sensor that’s on the line. No change. The guy who scanned it said he was getting a bunch of HVAC issues. But also got a code that said no communication with the Telematic control module. He said that could be the issue that’s causing the fan to not turn on high and for the back fan not to work at all but everything I’ve seen online says there’s no correlation. I don’t wanna buy the module if there’s no correlation any help would be great.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Before you buy the module, I would get a gauge like this and check the pressures on the low and high side to check if it needs refrigerant. You can also check for leaks with a UV flashlight and UV glasses, like this. If you aren't comfortable with using the gauges and reading it out what the system should have (it's on the label under the hood with GM). This might be a R1234yf car, as GM and others experimented with it shortly so if you see R1234yf, you need a R1234yf gauge, not a 134A. GM in general is known for using a lot of plastic (has been the case since the 2008 GFC after the bailout), and the AC condensers are prone to cracking at times. If you buy a small can, make sure it does NOT include stop leak - that is suicidal to these systems! You are better off buying surplus from someone who will look the other way about needing a EPA 609.
If there are no leaks and the system is low, you will need to add refrigerant - you cannot interchange R134A for R1234yf, so you will need to match what your system uses. You also cannot add too much or you will damage the system, so using a proper gauge like that is a must, not a suggestion - most cans come with one, but they do not always account for what is in the system well compared to a gauge like that. Some other common causes are the blower resistor, control modules or sometimes (albeit rarely) the cooling fans. I would check the refrigerant, blower resistor and modules first, even if you find it is low.
If that all looks good, come back with all of the codes and we can look at it closer.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thanks for the speedy reply. Now I dint mention that last year around this time I had some issues with my ac. Replaced the condenser and the compressor and other things I don’t remember. Now I do smell a little bit of refrigerant at times. And I may have a leak at the expansion valve. Will check tomorrow. But to have the back AC blower to stop working right as this is happening in the front seems highly unlikely a coincidence right? And the cooling fans not to work at the same time as well? I may just bring it to the shop because too much is going on lol
von
Antwort hinzufügen
Shawn Frederick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 42
Insgesamt: 254
