Zum Hauptinhalt wechseln
Die Xbox Series S ist die aktuelle Konsole von Microsoft, die ohne Laufwerk auskommt. Sie wurde mit ihrem großen Bruder, der Xbox Series X, am 10. November 2020 veröffentlicht.
Does not power on, have shorted capacitors
During some testing I found sticky residue on one of these chips “marked in red” and all of the capacitors in the “highlighted yellow” area are all shorted. The Xbox does not turn one and would like some input if possible thank you.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @tylerferguson
It’s very unlikely that all those SMD capacitors are actually shorted. What you’re seeing is the effect of measuring across a rail that’s being pulled down somewhere else — since the capacitors are all probably in parallel, they’ll all read short even though they’re fine.
The sticky residue you noticed is most likely flux. A bad IC on that rail can cause the short reading across the capacitors. In cases like this, it sometimes helps to remove the suspect IC and measure the rail again. If the short clears after removal, you’ve found your culprit. If it doesn’t, then the fault lies elsewhere in the power delivery path (often a MOSFET or regulator).
So in short:
  • Don’t assume all the capacitors are bad.
  • Clean the area to rule out conductive residue.
  • Focus on the ICs and MOSFETs tied to that rail.
  • Removing the suspect IC and re‑testing is a solid way to confirm whether it’s the source of the short.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
So did some testing and found that my 3.3v is shorted, I’ve tried to inject some power and can’t find anything heating up, I tried using ipa I don’t have a thermal camera.
von
Antwort hinzufügen
Tyler Ferguson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 31
Insgesamt: 93
