Zum Hauptinhalt wechseln
Reparaturanleitungen, Demontage- und Fehlerdiagnoseinformationen für das Apple iPad der 5. Generation mit Wi-Fi, erhältlich mit 32 oder 128 GB Speicher. Erschienen im März 2017. Identifizierbar durch die Modellnummer A1822. Ausgestattet mit einem 9,7" Retina Display und einem 64-Bit-A9-Prozessor.
Ipad doesnt charge when its turned on.
I have an Ipad 5th gen that charges normally when turned off. The moment it boots the Amps drop to 0. There's no debris and nothing is stuck in the charging port.
if its turned on the battery also doesn't go higher than 1%
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @schormn
The battery may need replacing.
Here's the ifixit iPad 5 WiFi Akku Austausch guide that shows what to do.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
hi, so i replaced the battery but i'm still having the same issue. do you think it might be a chip problem om the logic-board?
von
@schormn
Don't know Apple products that well but in the tablet go to Settings > Privacy & Security > Analytics & Improvements > Analytics Data and see if there's a panic log which may have data in it that may show what's happening.
If there is post it back here in your question above (click on Options > Edit) and maybe one of the other regular contributors more versed with Apple may be able to spot something.
von
hi, Ive figured out it was a chip on the logicboard. thanks for the help though!!
von
Antwort hinzufügen
James wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 47
