Motor is locked can this be fixed
How to unlocks motor
Ist dies eine gute Frage?
@fernandoro78917 generally yes but it will require a teardown and then a rebuild to eliminate the damage/reason from having been blocked. If you know what happened to that engine then you can also figure what needs to be done. Depending on the year, mileage etc. it maybe time to consider replacing the engine unless you have the right connection for the rebuild since it will require some machining.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 69
