Zum Hauptinhalt wechseln
Repair information for the fourth-generation Ford Ranger pickup truck (2019–2023).
Why my cluch pedal won't come back after I press it
Cluch problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@mphoamos you have an issue with the hydraulic clutch system. first make sure that you have enough fluid in your clutch master cylinder. Then open the clutch slave cylinder bleed nipple. If your pedal now returns to the initial position you will have an issue with the slave cylinder. If it not, then issue will be with the clutch master cylinder. This assumes that you have no leaks in your clutch hydraulic system and that you have enough fluid in it. If not, then you will first need to add fluids and bleed the lines. Let us know what you find out.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Mpho Amos wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 58
