Zum Hauptinhalt wechseln
Reparaturanleitungen, Demontage und Informationen zur Fehlerbehebung für die dritte Neugestaltung des beliebten Mac mini Small-Form-Factor-Desktop-PCs von Apple, der im Oktober 2024 auf den Markt kam. Mit M4- und M4 Pro-SoCs und mindestens 16 GB Unified Memory.
Safe way to unclip internal power wire?
The guide says to grip it by the wire closest to the connector, but that seems to be the way people are breaking the wire and the connector. (eg. when opening the mini to swap the ssd)
One end clips to the underside of the “power button assembly”, and another clips to the “antenna housing”.
PICOEZMATE is what the wire and connector are called.
edit: This seems to be the way
https://www.youtube.com/watch?v=dhEsgx8O...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sadly, the connector shown is not what Apple used for the power button connector. There is no lip at the front part of the connector as the vid implies you need to lift. Here the cable side needs to be lifted ever so slightly to clear the connector shell and then drawing it the rest of the way out at an angle.
To better see here's the connector in the connected condition. Note there is no lip at the front end to grab. While hard to tell the silver springs at the backside is what presses in on to the cables connector side to hold it.
Now looking at the cable disconnected we can see the contact blades which need to slide out to clear fully
As to a better way to disconnect this connector, I use the knife side of the Halberd Spudger to lift from the backside under the wires entry, then I gently pull on the cable at an angle. Most people are too rough and pull the cable not realizing there's a bit of a latch here and body and the contacts need to clear before you can pull on the cable
And yes it's not as easy as it should be! These are designed for auto insertion machines not people!
Hook and Slice your way to repair victory. Bild
Produkt
Halberd Spudger
$2.99
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Right. It seems that vid refers to an earlier design.
von
Antwort hinzufügen
D W wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 16
Insgesamt: 125
