Zum Hauptinhalt wechseln
The Ridgid R4030 is a 7" wet tile saw, powered by a 120V, 12 amp corded electric setup. Designed for cutting and shaping various types of tiles, it features a diamond grit blade, a cast aluminum table, and a continuous water pump for blade cooling. The saw is capable of making straight, bevel, diagonal, and miter cuts, and accommodates tiles up to 0.75" thick and 18" x 18" diagonally. Find repair and more information about this 50.2 lbs tile saw on this page.
armature seperate from housing
How to detach the armature from the housing
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
To detach the armature from the housing on a Ridgid R4030 tile saw, first, unplug the unit and remove the motor cover, motor brushes, and collet nut. Separate the two halves of the motor housing, disconnect the LED light wire, and then gently pull or tap the armature out.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
David Torres wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 55
