Zum Hauptinhalt wechseln
Informationen zur Reparatur und Demontage für das ROG Ally, einer tragbaren Spielkonsole von ASUS. Veröffentlicht im Jahr 2023 und erkennbar an der Modellnummer RC71L.
The power adapter cable isnt working properly
My charger is at the point where it will only work if you bend it. Usually, I would just replace the cable. But with this type of charger, it's obviously more complicated to do. Please advise on how to replace the cable.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Because the Asus ROG Ally charger is a sealed, proprietary USB-C unit, repairing the cable requires advanced soldering skills. Instead of trying to fix the worn cable, it is strongly recommended to purchase a new 65W (or higher) USB-C PD charger or a high-quality 100W USB-C cable, which will restore full 30W Turbo mode functionality.
Recommended Solutions:Best Solution: Buy a reliable third-party 65W+ USB-C charger (like Anker or UGREEN) to avoid the proprietary cable failure point.Preventative Measure: Buy a 90-degree right-angled USB-C cable to reduce stress on the port and cable, which prevents future bending issues.
f you must repair the current cable:Cut & Splice: You will need to cut the cable below the damaged area, strip the wires, and splice/solder a new USB-C connector (or a donor cable) to it.Multimeter Required: You must use a multimeter to map the wires correctly (positive, ground, and data lines) to avoid damaging the ROG Ally.Insulation: Ensure each wire is insulated with heat-shrink tubing to prevent short circuits.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
I bought a third party 65w usb c adapter, it charged normally but turbo mode went from 30w to 25w. Is that normal, does it only recognise its own propietary chargers to activate that 30w turbo mode, or is there a setting or two i can change to make it work properly
von
It’s normal might just be that you bought a different cord
von
Antwort hinzufügen
Obiwan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 26
Insgesamt: 177
