iPhone SE 2020 - Single vertical line on left edge
Hello !!
I need some troubleshooting help with an iPhone SE 2020. A single, hair-thin vertical line has appeared on the left side of the display.
Two things happened around the time it appeared: I recently had the battery replaced at a shop, and I've also been using a questionable charging cable.
Additional Symptom: I noticed that the behavior is tied to the phone's temperature. The line sometimes multiplies (more lines appear) when the device gets warm or while it is actively charging. Conversely, when the phone is cool, the lines disappear entirely.
Could you help me with these questions?
- Diagnosis: What is the most likely failure point here? Given that it reacts to heat, is this a thermal expansion issue with the LCD COF (Chip-on-Flex) bonding, or could it be pressure from the new battery?
- Part Notifications: If a screen replacement is necessary, will the iPhone SE 2020 throw an "Unknown Part" or genuine display warning message in iOS settings?
Thank you for your time and help!
Ist dies eine gute Frage?
