Zum Hauptinhalt wechseln
The seventh-generation Ford Fiesta focused more on a refined interior and advanced technology, including a move toward electrification before the model was ultimately discontinued. The core engine lineup was the 1.0L EcoBoost three-cylinder turbo, a 1.1L Ti-VCT and a 1.5L TDCi diesel. For the performance-oriented ST model there was a 1.5L three-cylinder EcoBoost engine delivering 197 hp and cylinder deactivation for better fuel economy.
Why doesn't my USB memory stick not work anymore in my Ford Fiesta?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @kevinstocks
Plug a mobile phone into the USB port in the car and check if the phone shows that it is charging.
If it doesn't then that's the reason why the USB memory stick isn't working as it needs power to operate.
The owner manuals for the model year range you selected don't specify but check if fuse #33 in the passenger cabin fuse block is OK.
If the phone shows that is it charging, have you proved that the USB memory stick is OK by inserting it into a computer to see if it is recognized and works?
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
@jayeff I will run the checks that you suggested! Thank you .... :-)
von
Antwort hinzufügen
Kevin Stocks wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 43
Insgesamt: 95
