Zum Hauptinhalt wechseln
Why is my generator shutting down after about 20 minutes
Every time I Crank It up it runs for 5 or 10 minutes and then it shuts off
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
@jerrygerman what is the exact model number for your Craftsman Generator and what have you already checked? Can you start it right away or do you have to wait a while?
von
Einen Kommentar hinzufügen
1 Antwort
A couple of possibilities:
--Low oil: Level may be "just about good" (usually halfway or higher in threads on filler neck, on portable inverter gens) when checked on level ground, and/or generator is actually running on sloped spot.
After a few minutes running, enough oil is splashed up and about in engine case that low-oil sensor calls for shut-down.
Fix: fill to recommended level, run generator as level as possible.
--CO monitor shut-down: wind changes, breeze blows a whiff of exhaust to CO monitor, and it shuts down.
Fix: position generator where CO accumulation is prevented (and at least 20' from habited structure). Some people take other measures to prevent nuisance-trips from CO sensor.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Jerry German wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 26
Insgesamt: 115
