Will these broken vias affect my mod?
Hi, I'm doing the pixelfx mod for my N64 and I'm using the full size HDMI port so I need to remove the AV port. I sucked up all the solder with my sucker, but didn't see that there a little bit left so when I removed the port it ripped out two vias will it affect the mod?
Ist dies eine gute Frage?
3 Kommentare
Hi!
I cannot help you with the mod, but I definitely recommend to fix those solder pads yes.. It's a good idea anyway to have everything intact before proceeding.
von koppie007
Aren't those anchor points for the AV thermal? cause it was soldered at the bottom of the board. I uploaded a pic of were the port was soldered
von Christopher D
You are correct. The downside is fully intact. You should be able to proceed.
von koppie007
