Zum Hauptinhalt wechseln
Erschienen im November 1998, identifizierbar durch die Modellnummer HKT-3020.
What is going on here?
Hi, I recently install the retro gem for my Dreamcast and when I boot the system it doesn't show the boot animation for the system only when its completed I went to debug menu and have hearts on all my installs as well as updated the firmware. I tried this on two TVs and it does the same thing. I have a Gamecube with a plug-in mini-HD to HD and it does something similar I used the same cable from that.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
8 Kommentare
Hi!
Is it possible to upload some pictures regarding the issue you are facing?
Bilder zu einer vorhandenen Frage hinzufügen
Thank you.
von
Can I upload video? pictures won't help
von
Yes you can!
Using Media
Thank you
von
Hi, I upload the videos in the first video it's the gamecube with the hdmi plug-in, the second one is the gamecube with S-video, and the third one is the dreamcast with the mini-HD to HD. I used the mini-HD to HD from the plug-in I couldn't get the av footage for the dreamcast cause I think I messed something up ....again, but it does the same thing as the gamecube plug-in. I hope its just the mini-HD to HD cable that's causing this. It's the basic edition of pixelfx mod
von
Okay, replacing the cable you can try indeed. It does not really look like a hardware issue in the first 2 pictures. More firmware related. Which firmware has been installed? Thanks!
von
3 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@dan0 Hi, I went on the retro gem discord and I was told that the delay in video is normal because the retro gem is booting.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Alright. Then it is normal behaviour. Thanks for sharing!
von
Sorry for the delay thank you
von
No problem at all! Have a great day :)!
von
Antwort hinzufügen
Christopher D wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 167
