Zum Hauptinhalt wechseln
Ein Desktop-PC, der aus im Handel erhältlichen Do-It-Yourself-Teilen zusammengestellt wurde, anstatt ein vorgefertigtes System eines großen Herstellers zu sein. Diese können auch von einem Systemintegrator unter Verwendung von Standardkomponenten gebaut werden.
good guides for replacing a power supply?
i did a bunch of research and i am reasonably certain that my power supply (Gamdias Kratos M1 550b) is failing. I’ve bought a replacement (MSI MAG A750GLS PCIE5), and I know that I’ll need to rewire the whole thing—I’ve read you should use all the cables that come with the new power supply. my PC was professionally built, but I am not a professional! I feel I can do it myself but, when I started taking my PC apart, I realized I don’t want to do this without studying up some first. what do you recommend i look at? i saw a few things here, but I don’t know enough to know which products/setups (if any) might be close enough, or which other components are critical to know about. (reading preferred over video, but video guides acceptable). the manual for the product is unhelpful to a regular person.
Also, when I began taking my PC apart, i noticed that the cables were held in place with tiny zipties. as my pc is a mini form factor, i imagine space inside there is quite limited. am i gonna need to invest in some mini zipties if i ever want to close my case again?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Here are three reliable written guides that walk you through PSU replacement clearly:
  • PC Build Advisor – Power Supply Installation Guide
    A detailed walkthrough covering removal, installation, and safety precautions. Includes photos and a checklist of connections.
    https://www.pcbuildadvisor.com/pc-power-...
  • TechBloat – Step‑by‑Step PSU Replacement
    Focuses on common pitfalls (like mixing modular cables between PSUs) and troubleshooting if your PC doesn’t power on after the swap.
    https://www.techbloat.com/how-to-replace...
  • XDA Developers – PSU Replacement Guide
    Offers practical advice on cable routing, securing the PSU, and ensuring all connectors (24‑pin, CPU 8‑pin, PCIe, SATA) are properly seated.
  • https://www.xda-developers.com/how-chang...
When choosing a PSU, a couple of points are worth keeping in mind:
  • Modular design: Modular PSUs are easier to work with since you only plug in the cables you need, which helps with airflow and cable management—especially in smaller cases. The trade‑off is that connectors must be seated properly, otherwise you risk issues like burnt pins. As long as the PSU isn’t obsolete and supports the current standards (ATX, PCIe, etc.), modular units remain a good option for future builds.
  • Efficiency certification: Look for an 80 Plus certified PSU (Bronze, Gold, or higher). This ensures better efficiency, less wasted power as heat, and generally higher build quality. Over the long run, it’s worth the investment.
  • Manufacturer reputation: Stick with reputable brands such as Seasonic, Corsair, Cooler Master, etc.
    A reliable PSU protects the rest of your components and saves you headaches down the line.
In short: modular units are convenient if you handle them carefully, and pairing that with an 80 Plus certified PSU from a trusted manufacturer gives you a solid, future‑proof choice.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
r g wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 37
Insgesamt: 148
