Zum Hauptinhalt wechseln
Informationen zur Reparatur, Demontage und Fehlerbehebung für das iPhone 16 Pro Max, das am 20. September 2024 als Nachfolger des iPhone 15 Pro Max veröffentlicht wurde. Dieses Flaggschiff verfügt über ein 6, 7 Zoll ProMotion OLED-Display, Apples A18 Pro SoC, eine Rückkamera mit drei Objektiven und die neue Camera Control Taste.
iPhone 16 Pro Max Volume Up button not working after a drop (still clicks)
My iPhone 16 Pro Max fell, and since then, the Volume Up button has stopped working.
Symptoms:
- The button still makes a "click" sound when pressed, so it's not physically jammed.
- The Volume Down button works perfectly and shows the volume bar on the screen.
- The Volume Up button does not show the volume bar or respond at all.
- I have already tried a force restart and checked the settings, but the issue persists.
Could this be a loose connector on the logic board caused by the drop, or is it more likely that the internal flex cable needs to be replaced? Since this is a newer model, are there any specific things I should watch out for before opening it?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
You, will likely have to open it to reseat or replace the flexible printed circuit (FPC) cable with the power and volume buttons on it. Replacement is difficult because you must remove the motherboard entirely.
Yes there is a technique to the 15 Pro Max and if you haven't used an iPhone in a while you'll find the screen connector has switched to the left side of the frame.
Read/Follow these guides:
iPhone 15 Pro Max
The flex cable that the volume and power button are on can be reseated once you have all the metal connector cover sheilds carefully removed from the logic board. I and not sure of the top of my head exactly which Lego style connector is the power/volume, therefore my recommendation is to reseat all of them carefully and gently a properly seated connector will give a very soft and stuble little clicky tactile feedback.
Be careful of the black foamy rubberized cover compound this can be scraped into a connector by accident easily pay close attention none ofadhesive-like material like matieral is stuck between the gold contacts. It can be removed easily with very fine tweezers.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Abdullah Kang wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 40
Insgesamt: 85
