Zum Hauptinhalt wechseln
ASUS X553MA - No power and no lights after hard reset and battery disconnect
I have an ASUS X553M laptop that will not power on and shows no indicator lights (power or charging) when plugged in.
I have already tried the following troubleshooting steps:
- Verified the AC adapter and wall outlet are working.
- Opened the laptop and performed a hard reset by disconnecting the internal battery and holding the power button for 60 seconds.
- Attempted to power on the device with only the AC adapter connected (battery removed), but still no lights or fan activity.
- Inspected and re-seated the keyboard/power button ribbon cable to the motherboard.
- Checked the DC power jack, which appears to be physically intact.
Since there are no signs of life even with the battery bypassed, I suspect a motherboard-level power delivery issue. Are there specific MOSFETs, fuses, or capacitors on this board known to fail that I should check with a multimeter?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@koporalaau98625 Are there specific MOSFETs, fuses, or capacitors on this board known to fail...? No, there is not. There is no pattern so you will need to do all the troubleshooting. "Checked the DC power jack, which appears to be physically intact" this is where you will need to start. Measure to see if you get the power from your AC adapter to the board side of the jack. Physically intact does not equal electrical functioning intact. Next,we would need to know what motherboard (X553MA?) your computer has. Post some well focused pictures of if with your Question. Bilder zu einer vorhandenen Frage hinzufügen
You could start off by checking the Asus X553MA Power Sequenceof the ASUS X553MA motherboard. The measurements shownAsus X553MA Power Sequence are taking in Diode mode. Let us know what you find out.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Koporala Aubrey malatji wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 72
