Zum Hauptinhalt wechseln
Model A1288 / 8, 16, or 32 GB capacity
503 Fragen Alle anzeigen
bottom half of touch screen not working after replacement
swapped out the digitizer and now the bottom icons do not work
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
It sounds like either a faulty digitizer or maybe something might have gotten unplugged when you put it back together. I would try to pull it back apart and make sure that everything is connected properly and if you still have an issue, then I would say that it is a faulty digitizer.
War diese Antwort hilfreich?
Bewertung 1
Do as Michael Stoffer writes, but also make sure contacts are clean and nothing is in the connector port.
Bewertung 1
Antwort hinzufügen
sheldon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 1,456
