Logitech G29 calibrates by turning hard left (-450°) on startup but is
Hello everyone,
I'm having an issue with my Logitech G29 (approximately 5 years old).
When I power it on, it does not perform the normal startup calibration (left → right → center). Instead, it immediately turns hard to the left (approximately -450°) and stops.
Here is what I have already tested:
- The wheel is detected correctly in Windows (joy.cpl).
- The wheel is detected correctly in Logitech G HUB.
- The steering axis is centered correctly (50%) when the wheel is physically centered.
- All buttons work normally.
- I tested it on both PC (Forza Horizon) and PS4 (Gran Turismo 7), and the same issue occurs.
- I tried different USB ports and different power outlets.
- I reinstalled G HUB.
- I downgraded G HUB to the March 2021 version and also tested the latest version.
- The firmware is up to date.
- The issue remains exactly the same.
There is no visible physical damage to the wheel.
Could this be caused by a faulty encoder wheel/position sensor, the force feedback motor, or the main PCB?
Has anyone experienced the same issue and successfully repaired it?
Thank you!
Ist dies eine gute Frage?
