My AC is not working.
The A/C is blowing air, and the air feels slightly cool, but it is not cooling the cabin effectively. Even with the A/C set to LO and the fan running, the inside of the vehicle remains very hot. The outside temperature is approximately 103°F. The airflow seems normal, but the cooling performance is much weaker than expected.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Easy things to do; check for dirty, clogged cabin air filter and replace, perform a reboot (onscreen, owner's manual, Tesla support, online search), check for software update. Eventually, vehicle ac systems suffer wear and tear with ac systems (once sealed) leaking refrigerant from damage. Ac repairs are not diy friendly, requiring more than casual knowledge using; refrigeration gages, vacuum pump, tools, service manual info, etc. Do not use store refill kits containing sealer as this guarantees a very expensive repair. Factory systems in vehicles, room ac, refrigerators and freezers do not have sealer installed. Sealer is an expensive band aid, contaminating systems repair shops may refuse to repair due to contaminating their equipment when connected. Sealer may result in a near complete rebuild to replace everything contaminated from sealer use.
von
Einen Kommentar hinzufügen
