Zum Hauptinhalt wechseln
Der Anfang 2022 auf den Markt gebrachte Asus TUF Gaming A15 ist mit AMD Ryzen 4000 Prozessoren, einer RTX- oder GTX-Grafikkarte und einem 15,6-Zoll 1080p-Bildschirm ausgestattet.
Laptop battery died and connecting it directly to wall doesn't work
Posting behalf of my friend, battery died so we removed it and tried to connect to wall directly but laptop doesn't start at all without the battery. Why is that? Why do we need the battery, can't I just directly connect to wall like other laptops.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Whether a particular battery powered device will run on AC power when the battery isn't installed is entirely up to the electrical engineers who designed it. As you've experienced, most laptops will run without a battery, but that's no guarantee they all will, as appears to be the case with yours.
Is the battery swollen? Otherwise if you're planning on running it on AC power all the time, why not leave the battery installed? Sounds like you might end up having to buy a replacement; your best bet for a cheap one would be on sites like AliExpress, Temu or WIsh, although the quality of the battery from those sites is a crapshoot. You may find deals on eBay and sometimes Amazon.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
thanks for the answer, I thought all laptops could run with AC. They'll get a new battery anyways so was just looking for a temporary solution
von
Antwort hinzufügen
Joseph wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 30
Insgesamt: 94
