Missing SMD component near Joy-Con rail FPC connector
Hi everyone,
I recently successfully replaced the M92T36 IC on a Nintendo Switch motherboard using a hot air station. The console now boots up and charges normally. However, I am now facing an issue with the Right Joy-Con.
When I slide the right Joy-Con into the rail, the console does not detect it as attached (it stays on wireless mode). I opened up the console again to inspect the area and noticed that the ribbon cable and the FPC connector look perfectly fine.
However, upon closer inspection of the small SMD component cluster right next to the FPC connectors, I noticed that one SMD component at the very bottom of the row is completely missing (likely blown away or knocked off accidentally during my hot air rework of the M92T36).
I have attached a micro photo of my board showing the missing component's empty pads, alongside some reference screenshots from the iFixit teardown guide for comparison.
My questions are:
1. Is this missing component a resistor (in-series) or a filter/bypass capacitor (to GND)?
2. What is the exact value/specification of this missing component (looks like a 0402 package)?
3. If it is a resistor on a data/detection line, can I safely bridge the pads with solder or a jumper wire to restore the detection functionality?
I have a multimeter, soldering iron, and hot air station ready to fix this. Any guidance or schematic insights would be greatly appreciated!
Thanks in advance for your help!
Ist dies eine gute Frage?
