Zum Hauptinhalt wechseln
Die Apple Smartwatch der 7. Generation mit optionaler Mobilfunkverbindung, herausgekommen am 15. Oktober 2021.
Review-iFixit-Fail-Apple Watch (45 mm Series 7) Screen Adhesive
I’m posting this as a community forum review since I couldn’t submit an Ifixit item review for my purchase (iFixit Order EU-XXX-ends on 921 - May 3, 2026) as it did not allow me to to post a review, hence I am posting it on this forum community.
I bought Apple Watch (45 mm) Series 7 screen adhesive. After an extremely thorough cleaning of the metal frame and the screen borders where the factory glue was applied, the adhesive appeared to fit perfectly. I clamped the screen and frame with four clamps for 48 hours, and it seemed fully bonded. However, after about two weeks, the bond started failing on one side and eventually the adhesive let go on roughly half the screen.
I removed the failed adhesive and reattached the display using a black gel adhesive commonly used for phone screen replacements. It has held securely for about one month and two weeks so far.
The adhesive I received was branded Tesa. I chose it thinking it would be a cleaner option, but in the end I had to switch to the messier gel method. I originally selected it because I was also replacing the Series 7 battery, and the battery replacement works great. The screen adhesive, though, did not.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
@andos82040, thank you for taking the time to write all this up, and really sorry to hear the Tesa adhesive didn't hold up, especially after such a careful install. Sorry too about the snag with leaving this as a proper review, that shouldn't have happened.
I've forwarded your feedback to our EU support team so they can take a closer look at both the adhesive itself and the review submission issue.
We're actively looking into it on our end, I'll follow up here if anything else comes up. But also be on the lookout for an email from our support team as well.
Appreciate you flagging both of these, it's genuinely helpful.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I'm sorry you had a problem. This is by far the most sensitive adhesive connection as without a good bond the Display Crystal can come off as you discovered.
One of the problems I've personally encountered is making sure the surfaces are fully clean. While they may appear to be clean a thin film can be present when using a low quality isopropyl alcohol as there is still solids within it that can interfere with the adherence of the adhesive. I only use reagent grade 90% isopropyl alcohol.
I also use Goo Gone to remove any remaining adhesive and wash the area down a few times to remove any of the Goo Gone as it too will prevent good adhesion. Any adhesive left will prevent a uniform seal with an edge more exposed.
Lastly clamping the crystal down is good as long as it's even across the crystal and shell. But surprisingly heat also makes a sizable difference. Not blistering hot just warm to you hand of both the crystal and shell body are warm.
I've tagged someone in IFixit about your concern as old stock is not helpful either.
War diese Antwort hilfreich?
Bewertung 1
@andos82040 I'd like to troubleshoot your Product Reviews concern. Could you provide a screenshot of the review page preventing the review from being posted?
Bewertung 0
Antwort hinzufügen
AndOS wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 42
Insgesamt: 179
