My old pc has no display pls help
My old pc has no display pls help windows xp
Ist dies eine gute Frage?
A PC that powers on but shows no display almost always comes down to RAM, the CMOS/BIOS, or the graphics output. Since it's an older Intel board with integrated graphics, work through these in order:
To help pin it down: what is the motherboard model number (printed on the board), and does the PC show any fans/LEDs or beeps when you press power?
War diese Antwort hilfreich?
This answer can be helpful, but not all ATX motherboards are fully modular, nor have the same parts. Also, don't motherboards require a storage drive in order to operate? Also, to give additional details, other motherboards may also use LED's to produce an error code, or the speakers, or neither.
The CMOS battery issue wouldn't be directed to this issue, as it could also just be the timestamp that just needs to be readjusted. As I've encountered this type of situation and the permanent fix to this would be that timestamp adjustment in the BIOS. Plus, resetting the BIOS and replacing the CMOS battery is just the bare minimum on this board. As I've already said, you will also have to get into the BIOS (rapidly pressing Delete, F11, F10, or Escape to get into the BIOS, if you don't know how) in order to change the timestamp.
Also, please note that this may be written with AI. Note that I said "may", not "definitely", since I have no definite conclusion that this is written with AI. The main reason why this could possibly be written with AI is because of the introduction and the conclusion.
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 132
9 Kommentare
Can you provide a bit more information on the configuration of your PC and the fault? Did it stop displaying after a power surge for example?
von honakrisi
@fouzanmasood at minimum we will need to know what motherboard this is and if it has integrated video circuitry or if it requires an external graphics card.
von oldturkey03
Intel motherboard and integrated Graphics it was actually my Grandfather,s iDK a lot about it
von N_A
@fouzanmasood
What is the model number of the motherboard?
usually the model number is printed on the board itself.
von jayeff
Your PC configuration does not have a monitor, or do you have the monitor and the PC isn't displaying anything to the monitor? Because if you don't have a monitor, then we can't help with that, since you will have to buy a monitor, not us.
von Theo Grefalda
4 weitere Kommentare anzeigen
