Zum Hauptinhalt wechseln
Auf der North American International Auto Show 2004 stellte Nissan einen komplett überarbeiteten Pathfinder für das Modelljahr 2005 vor.
Why is the engine heating up while drive with forced energy
I was driving one day and the fan belts had cut but I didn't know I thought it was battery issues because the steering was a bit hard so I was rushing to get home before anything happened. I got stacked in a small holdups and it stopped I fix the belt the next day but it misbehaving like moving with forced and so much noise. Later I saw it was over heating yet there is was in the radiator. What could have gone wrong.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I'd start with checking the head gasket. Running without a fan belt means your engine isn't getting cooled sufficiently and most modern cars have aluminum cylinder heads that warp easily when overheated.
Check the oil for presence of antifreeze, and the antifreeze for oil. You can also use something called block check to detect the presence of hydrocarbons coming from the radiator, which is another sign of a blown head gasket. Finally, a compression check and a leak-down test can also help identify a leaking head gasket.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Joseph Awobajo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 23
Insgesamt: 63
