two usbc ports damaged and not charging
Switch 2 (Damaged charging port repair)
Switch 2 with both charging ports damaged. Replaced both ports and only 2 data lines were damaged on the main bottom port. Installed new lines and they show good on tester. There were 6 total ground lines damaged. 3 on top and 3 on the bottom. Replaced both ports and both ports are getting .512 amps. System is not jumping to the next stage to charge or turn on system. Not sure where to look on these. I don't see anything like a M92/P13/BQ or caps that test/look bad. Has anyone else had anything similar that was obvious? Much thanks for any guidance.
Ist dies eine gute Frage?
Hi!
Is it possible to share some pictures with us regarding the repair?
Bilder zu einer vorhandenen Frage hinzufügen
Is the battery still fine? Did you checked for blown fuses on the board? Would check that one as well.
Thank you!
von koppie007
