Zum Hauptinhalt wechseln
Frage geschlossen
Boot normaly, after the apple, I get a white screen.
The screen was changed. I'm pretty sure that I did a mistake changing it.
When I boot, I get the grey apple, with the charging logo. Then the screen becomes white/blue. I can see some grey point on the white screen, the colour changes sometimes. The backlight is okay. If I plug it on an external monitor, I get a perfect image, and everything works. The video card is perfectly plugged to the main.
I saw on the internet that I only have to solder (?, sorry I'm french) a little thing.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It sounds like something isn't plugged in all of the way. When you put it back together, a cable could have came unplugged which would cause this issue. It also explains why the screen works fine when plugged in to an external monitor.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
Well thank you for your answer, but I tried it without putting everything back together first.
von
Is the screen you replaced it with new or used? If it is new, I would see if you could return it for a different one. If it is used, it sounds like you received a defective product. I could be completely wrong, and without being able to test it on other devices, I'm not 100% sure, but this is the conclusion that I have come to. Just trying to help.
von
Well the screen is new, but it wouldn't work at all ? I can see the grey apple and the loading logo. And this image is perfect, but then I get this weird white background... Besides, I already tried to replace it again :/
von
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 674
