Why my laptop is making noisey sound
Why laptop is making noise
Ist dies eine gute Frage?
I will suggest you check out the following guide: https://www.youtube.com/watch?v=RU-oC3FS...
War diese Antwort hilfreich?
This is a vague description of what you’re experiencing, but it’s a starting point. Here are some suggestions. First, try to determine what the laptop is doing while this noise is heard. Is it powering up or powering down? Are there many programs running at the same time? Or is it just sitting idle on your desk not being used? Then try to determine what part of the laptop the noise is coming from. Is it from the fans, the speakers, etc. Once you determine the answer to these two important questions, you’re halfway through discovering the problem. Take the information you’ve learned and try doing a general Google search or AI chat prompt asking your original question. Be sure to include all the information you’ve discovered, as well as the year, make, model, and all identifying details related to your laptop. I can almost guarantee you’ll find an answer that explains the troubling noise you’ve been hearing. If by chance,you’re not having any luck, search message boards on Support websites and you would be surprised how many people have already had to work through the same issue you are. Most of them are happy to help by explaining what you need to know and what you need to do going forward.
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 88
@haroldluwayo you need to be more specific. What king of noise? When does it make that noise? What have you already checked and what have you already tried?
von oldturkey03
Establish a laptop cleaning routine, having it professionally cleaned works well. A quarterly clean-up is ideal for occasional users.
von Einstein Johns
