Zum Hauptinhalt wechseln
Der neue GMC Yukon wurde 1991 für das Modelljahr 1992 eingeführt, während GM den Chevrolet K5 Blazer noch bis 1994 weiter produzierte.
I have a oil leak after changing my oil and filter
I have just bought my car 2000 GMC Yukon XL 2500 and I changed the oil and filter and now their is a leak around the filter.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
When replacing the filter, did you check for debris where the filter gasket seats? Sometimes the previous oil filter gasket may stick to the oil filter base resulting in two gaskets instead of one. Two gaskets may not seal and deform, leading to oil pressure leaks, There's also a possibility of an incorrect filter that can leak, Guess how I know? If the correct filter is used, most tightening procedures recommends turning it until it seats, then turning it another 3/4 of a turn to squish the gasket for a pressure proof seal. Review your owner's manual or ask someone knowledgeable about your Yukon.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Michelle Vaughn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 44
Insgesamt: 101
