Zum Hauptinhalt wechseln
Das Galaxy A9 (2018) bietet vier, richtig gehört, vier Rückkameras. Wow. Modellnummer: A920F/DS.
Samsung Galaxy A9 (2018) – Shuts down during boot/doesnt turn on
Hi everyone,
I could use some advice on an issue with my Samsung Galaxy A9 (2018).
Yesterday, some organic debris got into the USB-C cable connector and the phone's charging port, preventing it from charging. I cleaned both the cable and the port using isopropanol. After that, the phone charged properly again and worked normally for about half a day.
Current symptoms:
  • The phone suddenly powered off and does not respond to the regular power button at all anymore.
  • Using a key combination (Power + Volume Down), I managed to force-start it ONCE. It fully booted into the OS, showed around 94% battery, but crashed completely after about 1 minute. All other boot attempts failed during startup, crashing at different points during the boot animation.
  • Download Mode ("Custom OS...") can still be accessed and remains stable most of the time.
  • I cannot get into Recovery Mode (the phone does not respond to Power + Volume Up + Bixby).
  • When connected to a charger, there is no charging indicator/animation on the screen.
My main goal is to get it to boot up just one last time to pull a backup before replacing it.
Thanks in advance for any help or insights!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I would try to clean the port once again @nxghtmarem
Perhaps there is some debris left inside. And check additionally that the pins are not bended or have contact and are shorting themselves out.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Nxghtmare M wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 28
