Why are all of my dash lights on in my 2016 GMC Terrain Denali
I just bought a used Terrain Denali. First the tire pressure gauge came on. Each week a new dash light came on. The newest is the airbag light came on. Did I get ripped off or is this an easy fix?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Did you buy and drive it home before things began acting up? A weak or worn out battery along with poor/loose battery connections may contribute to mystery problems. The alternator and/or drive belt may be worn and should be tested. Battery voltage should be around 12.5vdc, alternator output should be around 14.5vdc. How old is the battery and has it been tested at your favorite auto store selling car batteries? Most provide free battery testing. Are both battery cable connections free and clean of corrosion from bluish white powdery deposits? Wet or dry deposits are from battery venting acid vapors, eventually eating copper wires underneath heavy battery cable insulation. A solution of water and baking soda will dissolve and neutralize deposits with a toothbrush. Plain water rinse.
von Teilen
Einen Kommentar hinzufügen
