Zum Hauptinhalt wechseln
Reparaturanleitungen, Informationen zur Demontage und Fehlerdiagnose für das Apple iPad der 9. Generation mit WLAN, erhältlich mit 64 oder 256 GB Speicherplatz. Veröffentlicht im September 2021. Identifiziert durch die Modellnummer A2602.
Stuck in Restore loop, can anyone help please?
My iPad is stuck in a loop. While using it, the screen went blank and then started buffering. I turned it off and back on and a Recovery page appeared. “This iPad encountered an issue while starting etc…I pressed continue and the next page was Diagnostic Data Collection, I selected “Send Data to Apple” and was asked to Enter Passcode, which I did, and then connected to the Wi-Fi Network. The next page said “Recovery Underway”. The following page stated “No Known Issues Found” and to “Restart iPad”. I followed this instruction and restarted. The Apple logo appeared, it beeped a few times and then after a few seconds the Recovery page appeared. Back to square one! I have tried this several times with the same result.
I have also tried to Restore while connected to my iMac and also through iTunes from a tutorial found on YouTube. All have had the same result. Can anyone help please?
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
@tracyharri54986 Any DFU debug lists?
von Teilen
Hi Theo, I’m not really sure what DFU bug lists are but thank you for replying
von Teilen
Einen Kommentar hinzufügen
1 Antwort
Boot the iPad into DFU mode and restore it using 3uTools
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Tracy Harrison wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 69
