Car will crank but won’t start…
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
@brianking81025 What sound does the car make when it cranks? Are there any fault codes?
von Teilen
Remove spark plugs and examine them. After several failed starting attempts of the starter turning the engine but engine never firing up, spark plugs should be soaking wet from cold start rich fuel mixtures. If you do not see or smell raw fuel on plugs, this may be a fuel issue; blown fuel pump fuse, blown injector fuse, damaged pump relay, dead pump, wiring damage. If fuel is injected and plugs are wet, spark from the ignition system needs to be tested.
With plugs removed, reconnect plug wires or ignition coils to plugs and ground plug bases to engine block. Have someone crank the engine. You should see spark on each plug.
No spark and no fuel on plugs points to; dead crank position sensor, sensor wiring, blown ecm fuse(s).
von Teilen
Einen Kommentar hinzufügen
