2019 Sportster Iron 1200, power won't turn on.
"I have a 2019 Sportster Iron 1200. After riding, I turned it off and tried to restart it shortly after. The power came on briefly, but when I pressed the starter button, I heard a 'click' sound and the entire power cut out completely—just as if the battery had been disconnected. I checked the fuses, and they are all fine. What could be the problem?"
Ist dies eine gute Frage?
This may be as simple as a worn out, partially charged or dead battery, battery connections corroded or loose connections, damaged wiring. If you can, try jump starting from another 12v battery, car/pickup truck/suv. Even a jump pack may help. If battery connections are clean and tight, you may have to test the battery at auto stores selling car batteries and capable of testing motorcycle batteries. Call ahead to be sure. Jump starting from another battery should result in one of two things; the engine cranks up and runs immediately or the same click sound (possibly indicating a worn starter or flooded engine locking up from excessive, raw fuel preventing engine turnover. If flooded, removing spark plugs and starting should blow out raw fuel. Plugs dried and put back on, the starter should crank and startup.
von F Dryer Teilen
